boolean algebra
Discussion in 'Homework Help' started by benPhung, Jun 25, 2010.
  1. benPhung
    Jun 25, 2010
    hello,
    i need help making the below expressions to product of sums:
    1. A'BC + EF + DEF'
    2. A + BC + DE (result should be a product of four terms.)
    Thank you!
  2. jstrike21
    Member
    Sep 24, 2009
    104
    Try making a karnaugh map and create the product of sums using the zeros
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
    I am only giving you the answer for the second expression because I know how painstaking working with 5 varialbe maps is. It is:
    F=(A+B+E)(A+C+E)(A+B+D)(A+C+D)
    If I had done it by hand I would go with a karnaugh map and zeros, as jstrike21 said. I would avoid Boolean algebra as it would require too much imagination and elaboration.
    I say "if" because I used a software! If you are taking a class on boolean logic or logic circuits I recomend doing your maps by hand, as it is an indispensable skill. However, if this is only a part of your lesson (in digital circuits for example) then a software can be time saving. I use Karnaugh Map Minimizer, a free software. Only one warning though: in 5 variable maps like this one, in the table that lists the maps positions (00000,00001, etc) the variables' order is EABCD and not ABCDE. It took a while until I figured it out.
