boolean algebra to nand
Discussion in 'Homework Help' started by Wizardi, Mar 18, 2007.
  1. Wizardi
    Mar 18, 2007
    5
    I have a problem getting this following boolean equation into to using only nand gates. AB+DA+CA+DCB ... just can't figure it out with the basic rules of boolean algebra.
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Have another look at DeMorgan's Theoram. (Theorem? Theorom?) Have another look at DeMorgan's stuff.
    And remember... nobody restricted anyone to the use of two-input gates...
  3. Wizardi
    Mar 18, 2007
    5
    That was given to me in the assignment that I can you more than 2 inputs. But my problem is how to get complenment lines in order to form nand gates? please elaborate your answer
  4. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    You must use NAND gates exclusively, yes? Your outputs get inverted, yes?
    If AB=X, then (AB)'=X'.
    That's where DeMorgan's Theorem comes in.
    The circuit can be made with three gates from a 7400, one from a 7410, and one from a 7420.
    If you are still having trouble, try making a truth table for the problem.
  5. nomurphy
    Aug 8, 2005
    567
    12
    See attached:
  6. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Please note [' = NOT] and I am not simplifying the expression in the following:
    AB+DA+CA+DCB
    Double NOT the expression (because double NOT does not alter the expression):
    (AB+DA+CA+DCB)''
    Using DeMorgans (A+B)' = A'.B'
    Therefore:
    ((A.B)'.(D.A)'.(CA)'.(DCB)')'
    Which can be implemented using purely NAND gates.
    You may be advised to look at simplifying the expression, although that depends on what your assignment requires.
    Dave
  7. Wizardi
    Mar 18, 2007
    5
    I see your point dave but the way you did it requires a not gate and nand gates...And my assignment was to use only nand gates.
  8. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    It doesn't, it requires:
    - 1x4-I/P NAND
    - 1x3-I/P NAND
    - 3x2-I/P NAND
    Incidently, you can also make a NOT gate out of a 2-I/P NAND gate by tying the two inputs together.
    Dave
