boolean algebra simplification help~
Discussion in 'Homework Help' started by minakrn, Feb 4, 2007.
  1. minakrn
    Feb 4, 2007
    hi guys ^^;
    well.. i am new here and would greatly appreciate some help with the following algebra simplification problems (i have included my work so that i may compare the logic with you guys)
    1) AC + ABC + BC
    A + C + ABC + BC -> De'Morgans
    A + ABC + BC + C -> Commutative
    A(1 + BC) + BC + C -> Distributive
    ..stuck~
    2) (A+B)(A + B)
    (A * B)(A + B) -> De'Morgans
    (A * A * B) + (A * B * B) -> Distributive
    [simplified answer]? A + B -> Identity
    3) ABC + AC
    C(A * B + A) -> Distributive
    C((A + A)(A + B)) -> Distributive
    [simplified answer]? C * (A + B) -> Identity
    4) BC + B(AD + CD)
    BC + BAD + BCD -> Distributive
    B(C + AD + CD) -> Distributive
    ..stuck~
    5) (B + C + BC)(BC + AB + AC)
    I basically tried to distribute everything.
    Cancelled using identities and got stuck~
    6) XYZ + XYZ + XYZ + XYZ
    XZ + XYZ + XYZ -> Adjacency
    XZ + X(YZ + YZ) -> Distributive
    ..stuck~ [Question: Can you simplify (YZ + YZ) to 1? (using the identity much similiar to X + X = 1)
    7) XYZ + XYZ + XYZ + XYZ
    XYZ + XYZ + XY -> Adjacency
    Z(XY + XY) + XY -> Distributive
    Wow..that was tedious~
    Well..there you go ^^;
    Best regards~
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Hi and Welcome to All About Circuits!
    Can I ask for one point of clarification? When you write for example AC are you meaning [ NOT(A) AND NOT(C) ] or are you meaning [ NOT(A AND C) ].
    Thanks.
    Dave
  3. minakrn
    Feb 4, 2007
    Hi Dave and thanks ^^;
    Well..what I meant was:
    [ NOT(A) AND NOT(C) ] -> so it looks more like this A C.
    BTW: can you tell me what the difference is? Is it because the De'Morgans concept?
    I apologize for this confusion.~
  4. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    To understand the difference, think about the truth tables:
    A | NOT(A) | B | NOT(B) | A.B | NOT(A.B) | NOT(A) AND NOT(B)
    0 | 1 | 0 | 1 | 0 | 1 | 1
    0 | 1 | 1 | 0 | 0 | 1 | 0
    1 | 0 | 0 | 1 | 0 | 1 | 0
    1 | 0 | 1 | 0 | 1 | 0 | 0
    Hence NOT(A.B) is a NAND (NOT-AND) gate, whereas (NOT(A) AND NOT(B)) is a NOR (NOT-OR) gate.
    Clearer? EDIT: Apologies, the truth table hasn't come out as I expected, I recommend you write it down from the above layout but properly format the columns!
    I will have a look through your initial workings when I get a moment later.
    Dave
  5. minakrn
    Feb 4, 2007
    Oh, is that what you meant?
    Well, in that case, I see where you are coming from.
