[Boolean algebra] Mismatch between algebra and karnaugh map?
Discussion in 'Homework Help' started by Josh Samman, Apr 5, 2013.
  1. Josh Samman
    Mar 29, 2013
    11
    Look at this equation:
    f = (a + c)*(a' + b)
    I solve it by distributing the terms:
    f = a'(a + c) + b(a + c)
    = aa' + a'c + ab + bc
    = a'c + ab + bc --> Resolution
    Then i plot it into the Karnaugh map:
    * Sorry for the bad drawing :rolleyes:
    And i get:
    f = a'c + ab(from the map)
    f
    = a'c + ab + bc --> (comparing to the resolution by algebra the "bc" term is missing).
    I look at the map and i know right away that the "bc" term gets simplified by ther other 2 (regarding that the bold 1's in the map are the "bc" term).
    Now i don't know how i can simplify f = a'c + ab + bc to f = a'c + ab using algebra only! :confused: How to do it? There's any rule i'm missing in there or what?
  2. MrChips
    Oct 2, 2009
    12,652
    3,461
    Expand each of the three terms a'c + ab + bc
    For example,
    a'c = a'b'c + a'bc
    Take it from there.
  3. Josh Samman
    Mar 29, 2013
    11
    F = (a'bc + a'b'c) + (abc + abc') + (abc + a'bc)
    = a'bc+ a'b'c + abc + abc';
    = [a'c(b+b')] + [ab(c'+c)]
    = a'c + ab
    \o/ - Thank you man, for the help ;)
