Boolean Algebra Ideneties for VARIABLES
Discussion in 'Homework Help' started by antonykmansour, Apr 3, 2016.
  1. antonykmansour
    Apr 3, 2016
    Need help doing this for an exam - I keep getting the wrong answer
    ABC+ ABC' + AB'C + A'BC = AB + AC + BC
    Thank you in advanced
  2. MrAl
    Distinguished Member
    Jun 17, 2014
    2,557
    515
    What did you do so far?
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Hint: Try adding redundant terms to either side of the identity in such a way that the result is unaffected.
    2nd Hint: Make yourself a truth table to verify that the expression is indeed an identity.
  4. WBahn
    Mar 31, 2012
    18,087
    4,917
    How can we tell you why you keep getting the wrong answer when you don't show us what you did or what answer you got?
    Can you find two terms on the left that reduce to the first term on the right?
    Can you find two terms on the left that reduce to the second term on the right?
    Do you see a pattern developing?
