So, you used the Karnaugh map incorrectly. You need to wrap the cells around as in a cylinder.Unfortunately I've got to prove this works using Boolean Algebra only. I'm not allowed to use Karnaugh maps for this particular problem.
That's why I know the answer (having used Karnaugh to arrive there), but was struggling to see how to get to the same place with Boolean algebra alone.
Thread starter | Similar threads | Forum | Replies | Date |
P | Boolean Algebra problem , need help | Homework Help | 9 | |
L | Help With Boolean Algebra | Homework Help | 3 | |
N | boolean algebra help. | Homework Help | 11 | |
D | boolean algebra help | Homework Help | 3 | |
R | Help needed with Boolean Algebra and DeMorgan | Homework Help | 9 |
