Boolean algebra basics
Discussion in 'Math' started by Airmax, Feb 17, 2008.
  1. Airmax
    Feb 17, 2008
    Hey there guys,
    I have just started studying electronics at uni and have started boolean algebra. I am having a little problem simplifying the expressions as most people seem to. I am aware of the laws but I am having troubles understanding how to move and manipulate variables to be able to apply the laws.
    A.B + B.C + A'.C = Z
    With this expression I just dont know where to start. What Im not sure of is the rules to moving the variables around. If someone could break this expression down to step by step sections it would be a great help.
    Trev
  2. S_lannan
    Jun 20, 2007
    247
    okay. i don't blame you it all looks like crap until you actually see what it means in logic.
    This form of expression is called a sum of products.
    Basically i see it as this
    A AND B
    OR
    B AND C
    OR
    NOT A AND C
    graphically ?
    look at the attachment
    This equation is taken straight from a truth table
    It's saying this and this... OR this and this.... OR this and this - will make the Z go high.
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    The first thing you should look for is common factors. Lets look at you equation for example:
    And lets look at just the first two terms:
    A.B + B.C
    It should be clear that B is a common factor to both terms, so simplified:
    A.B + B.C = B(A + C)
    Conversely, from your first equation you could have looked at the second two terms:
    B.C + A'.C
    Again, it should be clear that C is a common factor, so:
    B.C + A'.C = C(B + A')
    Therefore there are two equally valid simplifications for this equation:
    B(A + C) + A'.C = Z
    A.B + C(B + A') = Z
    These are equally valid simplifications of the original expression for two reasons:
    1) The implement the same output for a given set of inputs.
    2) They are implemented using the same number of gates.
    When looking at common factors, look for identities to remove gates from the expression. And you should also look at apply DeMorgan's theorems, to more advanced problems, particularly when you need to look at implementing a function using universal; gates. If you've only just started studying Boolean algebra, you come onto these in due course.
    Dave
  4. Airmax
    Feb 17, 2008
    Thanks heaps guys, your advice has been greatly appreciated and things are starting to make more sense.
    Cheers !!
    Trev
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
  6. aliashar86
    Nov 23, 2006
    71
    good reply given by "Dave" .
    ok u also if could get "Digital fundamental by Floyd" it could also help u alot. also as this subject is mostly connected to ur practical work so try to plot the expression using the gates.
    for multiplication: AND
    for Addition: OR gate.
    that will make a proper sense.
