Book answer wrong (quick answer check)
ihaveaquestion
Joined May 1, 2009
314
Hi everyone,
Rather simple question:
The current entering the positive terminal of a device is i(t) = 3e^(-2t) A and the voltage across the device is v(t) = 5di/dt V.
Find the charge delivered to the device between t = 0 and t = 2 s.
since i = dq/dt, q = integral of i with respect to t
I'll have my integral sign be [
So q = [ i dt = [ 3e^(-2t) dt = (-3/2)e^(-2t) evaluated from 0 to 2:
-3/2e^(-4) - (-3/2) = 1.47 C
Answer in the back of the book = 1.297 C
Who's wrong?
Thanks in advance.
Papabravo
Joined Feb 24, 2006
21,227
I think your answer is correct. If you differentiate the result of the integration; do you get back the original integrand? Check! There is no problem with the numerical evaluation.
FWIW the book's answer just happens to be what you get if you compute
Rich (BB code):
-3/2 * [ e^(-2) - 1] = 1.297 Coulombs
This would also be correct if t was equal to 1 in the original problem.
Have a bit more confidence next time. I think you've earned it.
