Bonding Ultrasonic Transducer Horn
Discussion in 'General Electronics Chat' started by Mad Professor, Nov 17, 2011.
Thread Status:
Not open for further replies.
  1. Mad Professor
    Thread Starter Active Member
    Apr 15, 2009
    133
    Good day all.
    I own a Kerry ultrasonic cleaning bath, but the ultrasonic transducer horn has started coming away from the base of the tank.
    Can anyone here recommend what compound to use to rebond the ultrasonic transducer horn to the base of the tank?
    The ultrasonic transducer horn is made out of aluminium, and the tank is stainless steel.
    The ultrasonic transducer horn looks very much like this one:
    Thanks for your time.
    Best Regards.
  2. shortbus
    Sep 30, 2009
    4,092
    1,672
  3. guhankannan
    Jun 21, 2013
    ultrasonic circuit diagram regarding
  4. atferrari
    Jan 6, 2004
    2,663
    784
    Is that a question?
    Could you rephrase it?
  5. Metalmann
    Dec 8, 2012
    700
    223
    I would try clear silicone.
  6. studiot
    Nov 9, 2007
    5,005
    515
    I am not familiar with you cleaning machine, but have done quite a bit of ultrasonic testing.
    My experience suggests that you should not use a bonding agent that sets hard or rigid if the u/s wave has to pass through it.
    It is normal to use a 'coupling gel' in u/s testing. Wallpaper paste works well, but would not be strong enough for mechanical support.
    Perhaps the silicone suggestion will work.
    Or bond it round the rim only and dam a coupling fluid inside.
    go well
  7. ErnieM
    Apr 24, 2011
    7,436
    1,625
    Gee, back when we put an ultrasonic transducer inside a submarine to check how much water was inside a nuclear reactor (seriously, I did that) we just used a thin coat of oil. In that setup the transducer had a spring holding it to the tank.
    Vaseline also works well,as does just plain water.
    A thin coat of just about any epoxy should do the trick permanently. You want a thin coat with few bubbles as bubbles scatter the wave.
    As any boat using a thru hull depth sounder needs epoxy to stick it down to the boat any marine store should have *exactly* what you want.
  8. GopherT
    Nov 23, 2012
    6,303
    4,023
    Any bonding agent that is flexible will absorb ultra-sonic energy and, the more rigid the better the U/S energy will be transmitted. The concerns is that a very rigid bonding agent will be blown apart by the ultrasonic energy (similar to what happened already - apparently). If you see any rigid epoxy laying around the old bonding area, try to find something less rigid (expect a less powerful sonic bath).
    Dow, 3M and Henkel each have excellent acrylic, epoxy and urethane structural adhesives that will bond aluminum to stainless steel. Use their product selector to enter the two different materials you are bonding. The stronger the adhesive for your substrate (Al and SS), the more rigid adhesive you can select, and more energy transmitted.
  9. studiot
    Nov 9, 2007
    5,005
    515
    My practical experience can't agree with this, nor would it be considered best practice.
    Any boundary between a rigid adhesive and the bonded metal will appear on test as reflection surface. There will, of course be two such boundaries for an adhesive.
    The fluid couplant appears transparent to the u/s waves.
    Sorry I no longer do this stuff so cannot show scope pictures, perhaps some other member has access to u/s testing gear and can do this?
  10. paulktreg
    Distinguished Member
    Jun 2, 2008
    622
    124
    The ultrasonic cleaners I've worked on have used a very hard adhesive to bond the crystals. Perhaps something like liquid metal would do the job? The only problem I see is whatever adhesive you use you may only get one chance to get it right.
  11. Markd77
    Sep 7, 2009
    2,803
    594
    I suspect Mad Professor has solved it of given up already, the thread started in 2011. The new question (in the loosest possible definition) is:
  12. studiot
    Nov 9, 2007
    5,005
    515
    Good catch Mark
  13. Wendy
    Mar 24, 2008
    20,772
    2,540
    Guys, this is pure necroposting, along with a hijack. Since the OP seems to be finished with this thread I'm shutting it down. If someone wants to continue the conversation please pick it up elsewhere.
Thread Status:
