Body of diode is melting
Discussion in 'General Electronics Chat' started by pradeeba, Jul 31, 2008.
  1. pradeeba
    Thread Starter Active Member
    Feb 27, 2008
    104
    Hi all,
    In a batch of 25 SMPS kept in the oven with full load for 60 DegC. In that in 5 board's o/p recitifier diode starts melting like icecream after 1 hour. what may be the reason for this?
  2. mik3
    Feb 4, 2008
    4,846
    63
    Is the diode capable of working at this temperature ? Check the datasheet
    Or maybe the oven is not keeping the temperature at 60 degrees but brings it at higher temperatures, broken thermostat ......
  3. pradeeba
    Feb 27, 2008
    104
    Diode operating temperature is till 175DegC. oven temperature is also found to be correct.
  4. mik3
    Feb 4, 2008
    4,846
    63
    Thats intersting, i never tried to put a circuit in the oven to check it at the limits. Try to put a diode alone in the oven and see what happens. Maybe the diode's temperature rises from the current through it too and in combination with the oven it melts.
  5. pradeeba
    Feb 27, 2008
    104
    checked the circuit current it is under limit only.
  6. mik3
    Feb 4, 2008
    4,846
    63
    Can you tell us the diode's part number?
  7. pradeeba
    Feb 27, 2008
    104
    part number is MUR120
  8. John Luciani
    Apr 3, 2007
    477
    How much power is being dissipated in the diode? What is the thermal resistance of
    the diode? Does the diode have a heatsink?
    Since you have an ambient temperature is 60DegC the diode can tolerate a maximum rise
    of 115DegC (175-60). The temperature of the diode junction is
    Tj = P * (Rjc + Rcs + Rsa)
    where Rjc is the thermal resistance of the diode junction to the diode case
    Rcs is the thermal resistance of the diode case to heatsink and
    Rsa is the thermal resistance of the diode sink to air.
    If there is no heatsink then replace (Rjc + Rcs + Rcs) with the junction to ambient
    thermal resistance from the manufacturer's datasheet.
    (* jcl *)
    www.wiblocks.com
  9. pradeeba
    Feb 27, 2008
    104
    I had kept 25 boards only 5 board's diodes are getting melted. moreover am drawing only 200mA current. so heatsink is not necessary.
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    How much air flow is in this oven? Sounds like hot spots to me.
    I once had a problem with a TEC (peilter cooler) under a table regulating a laser diode temperature (the diode was being tested). Every Monday the cooler had run away, what the problem was the table had a deep lip, trapping hot air. With no movement over the weekend the stagnent air overheated the hot side of the cooler and...
    The answer was a fan that was plugged in for several minutes, after that people walking and working around the station did the rest.
  11. Norfindel
    Mar 6, 2008
    235
    9
    Do the supplies mention max operating temperature?
  12. John Luciani
    Apr 3, 2007
    477
    How do you know the current is only 200mA? Have you checked to see if there
    is a ripple current that is much higher? The die area in that device is small. It would
    not take a long duration current to exceed the maximum junction temperature.
    Are there any airflow requirements for the supply?
    (* jcl *)
  13. pradeeba
    Feb 27, 2008
    104
    I have checked the load current and also the ripple current, all are under limit only.
  14. Wendy
    Mar 24, 2008
    20,772
    2,540
    I think I asked this, but is the air being moved in this oven? It matters, if it isn't then the only place that is regulated is the thermocouple/sensor.
  15. pradeeba
    Feb 27, 2008
    104
    Air is not moved inside the oven
  16. Wendy
    Mar 24, 2008
    20,772
    2,540
    OK, you probably are fighting hot spots, and some pretty extreme ones. Bet the problem is mostly at the top of the oven. In a well insulated oven you can have as much as 100 degree C between the top and bottom. I have spent my share of time servicing burn in ovens. You might try some measurements with a thermocouple, and think about how to circulate the air. It doesn't need to be vigorous, just enough to mix the air up, moving the air from the top to the bottom. Remember, the parts are generating heat also, and it all adds up.
  17. pradeeba
    Feb 27, 2008
    104
    Am sorry. The oven is Hot air oven only. but all boards were kept in bottom shelf and all the diodes are not melted only few are melted
  18. Wendy
    Mar 24, 2008
    20,772
    2,540
    Still, they didn't melt themselves. Have you done local area readings with a thermocouple? I'm willing to bet you have a huge variation in temperatures throughout the oven, which is why most burn in ovens circulate their air.
    I've been known to take thermocouple readings through the doors of vacuum ovens, running a wire through the door seal isn't hard. In the case of the vacuum ovens, I used teflon tape (as in plumbing tape) to form a temporary seal.
    Seriously, I've had ovens that overtemped just from the product. The heaters, other than warming the chamber up after it was turned on, didn't have to work a bit. This is also why most burn in ovens have vent holes, to allow for some cooling if needed.
  19. pradeeba
    Feb 27, 2008
    104
    Thanks for the reply. I will measure the oven temperature with thermocouple.
