bode plot
MrAl
Joined Jun 17, 2014
11,496
Hello there,
Mike:
You probably want to check your Laplace function in post #3 because that seems to yield the wrong result. I'll double check this too. It could be that LTSpice leaves out the constant gain in the Laplace function.
CHECKED:
Ok, it's just that LTSpice uses frequency in Hertz instead of angular frequency w. If we plot from 0.01/2/pi to 100/2/pi and for x=f*2*pi we get the same plot as post #2 for the amplitude.
Full:
The amplitude function is:
|V|=(30*w*sqrt(w^2+100)*sqrt(w^2+144))/(sqrt(w^2+64)*sqrt(w^4+71*w^2+625))
and so the amplitude in db is:
Vdb=20*log10(|V|)
You can use that to check your results, but the plot comes out the same as your plot in post #2.
The x axis variable is 'w' not 'f in Hertz' just to clear that up, and w=2*pi*f.
Again you are probably just overlooking something simple. It's hard to read your sheets though because the writing is so faint.
