Bode Plot & AC sweep in PSPICE A/D
Discussion in 'The Projects Forum' started by bluegreenpurple, Apr 20, 2014.
  1. bluegreenpurple
    Apr 20, 2014
    Good day,
    Can someone assist me with my code? I am working in PSPICE A/D (no schematics). I am trying to obtain a bode plot from the following code:
    V3 1 0 DC 12V
    V2 2 0 DC -12V
    V1 3 0 SIN(0 100m 10k 0 0)
    C1 3 4 47uF
    R1 1 4 75k
    R2 4 2 750k
    Q1 1 4 5 npn
    R3 5 2 3k
    C2 5 6 47uF
    R4 1 6 500k
    R5 6 2 600k
    Q2 7 6 8 npn
    R6 1 7 1.9k
    R7 8 2 65
    C3 7 9 47uF
    R8 1 9 185k
    R9 9 2 700k
    Q3 10 9 11 npn
    R10 1 10 100
    Q4 1 11 12 Q2N3055
    R11 12 2 10
    C4 12 13 47uF
    R12 13 0 8
    .tran 1ns 4ms
    .MODEL npn NPN(BF=120 CJC=20pF CJE=20pF)
    .MODEL Q2N3055 NPN(IS=4.66E-12 BF=360 VAF=100 IKF=0.25 ISE=3.339E-11
    + BR=2 ISC=5E-9 RB=3 IRB=0.001 RBM=0.4 RC=0.04 CJE=5.802E-10 VJE=1.2
    + MJE=0.45 TF=8E-8 XTF=1 ITF=3 PTF=120 CJC=2.121E-10 MJC=0.4 TR=2.55E-6
    + XTB=1 )
    .probe
    .op
    .end
    I tried to do the AC sweep but my Vin which is labeled V1 is zero when I do the AC sweep... Here is what I coded for the AC sweep:
    V3 1 0 AC 12V
    V2 2 0 AC -12V
    C1 3 4 47uF
    R1 1 4 75k
    R2 4 2 750k
    Q1 1 4 5 npn
    R3 5 2 3k
    C2 5 6 47uF
    R4 1 6 500k
    R5 6 2 600k
    Q2 7 6 8 npn
    R6 1 7 1.9k
    R7 8 2 65
    C3 7 9 47uF
    R8 1 9 185k
    R9 9 2 700k
    Q3 10 9 11 npn
    R10 1 10 100
    Q4 1 11 12 Q2N3055
    R11 12 2 10
    C4 12 13 47uF
    R12 13 0 8
    *.tran 1ns 4ms
    + XTB=1 )
    .AC DEC 20 20Hz 100megHz
    .Print AC VM(13) VP(13)
    .probe
    .op
    .end
    I believe that I am missing something or coding Vin incorrectly, could someone please direct me into the right direction? I would greatly appreciate it. Thanks in advance for your help.
  2. mvaseem
    Member
    Jan 31, 2014
    48
    8
    You don't have AC source in your circuit. This is required to do AC analysis.
    Change V1 to AC source. Also don't chnage the bias voltages V2, V3. Leave them DC.
    See below code -
    V3 1 0 DC 12V
    V2 2 0 DC -12V
    *V1 3 0 SIN(0 100m 10k 0 0)
    V1 3 0 AC 1V
    C1 3 4 47uF
    R1 1 4 75k
    R2 4 2 750k
    Q1 1 4 5 npn
    R3 5 2 3k
    C2 5 6 47uF
    R4 1 6 500k
    R5 6 2 600k
    Q2 7 6 8 npn
    R6 1 7 1.9k
    R7 8 2 65
    C3 7 9 47uF
    R8 1 9 185k
    R9 9 2 700k
    Q3 10 9 11 npn
    R10 1 10 100
    Q4 1 11 12 Q2N3055
    R11 12 2 10
    C4 12 13 47uF
    R12 13 0 8
    *.tran 1ns 4ms
    + XTB=1 )
    .probe
    .op
    .end
  3. bluegreenpurple
    Apr 20, 2014
    Thanks for responding.
    In order to change V1 to an AC source would I code as follows:
    V1 3 0 AC 100mV
    OR would I just leave the sinusoidal source out in order to do the AC sweep and produce the Bode Plot?
    Thank you.
  4. mvaseem
    Member
    Jan 31, 2014
    48
    8
    AC analysis is a small signal analysis where the circuit is linearized about bias point. Having correct bias point is important in case of AC analysis, not the AC amplitude.
    The AC source amplitude would act only a multiplier, but would not change the shape of output curve (bode plot -gain curve).
    If you directly want to see the gain wrt freq, just leave the amplitude of AC as 1 and plot the output.
    If you provide it something else, like 100mv, would need to divide the output plot by 100mv. This would lead to same curve as with 1V.
