I have to draw a BM Plot with the following characteristics using frequencies ranging from 10Hz to 1MHz.
1) Av(mid)= Vo/Vin = 238
2) Input lead network: f = 200Hz
3) Output lead network: f = 1Hz
4) Collector lag network: f = 10MHz
5) Base lag network: f = 25KHz
6) Bypass capacitor network: f = .05Hz
I know the mid-gain and the upper and lower break frequencies but after that I'm not sure how to proceed.
I also need to find the output voltage if Vin = 10mVpp and the phase difference between Vin and Vout at the following frequencies: 200Hz and 2.2KHz.
