1. Lightfire
    Oct 5, 2010
    690
    21
    I wanna play with boats. :) A toy boats. :D
    Um, I heard of using a dynamo and an AA batteries. But I'll need some good advice from you veterans. :D
    Pls forgive my favor. OK?
    Thanks...
  2. kubeek
    Sep 20, 2005
    4,689
    806
    What would a dynamo be for? You need some motor to drive and servo to steer at least.
    Do you want it radio controlled? That´s not really an easy goal to achieve in DIY.
  3. Lightfire
    Oct 5, 2010
    690
    21
    Oh, okay. a motor. :) not dynamo.
    I dont want it to be a radio controlled if that was so difficult...
    any help?
  4. kubeek
    Sep 20, 2005
    4,689
    806
    What should it do then? Just swim in a circle? Or some programmed course?
  5. magnet18
    Dec 22, 2010
    1,232
    125
    You can start with making one go straight, use a motor with a small propeller on it and hook it to some AA batteries.
    After that if you still want control over it you need to hook it to wires, or go wireless which is difficult to do by yourself, like kubeek said, or expensive, as you need to buy a transmitter and receiver and such.
    You might be able to disassemble a toy remote control car and use it if you're really clever about how you mount things.
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    You could always put a computer fan on a block of wood, with batteries. That fits your model. :D
  7. Markd77
    Sep 7, 2009
    2,803
    594
  8. magnet18
    Dec 22, 2010
    1,232
    125
    Or, you could build a hovercraft!
    One of those simple motors and a 9 volt did it for me when I was your age, after tuning the air downturn thingy size, I got them to shoot across the kitchen about 3 inches in the air and at about 10 mph (faster than you can run) (I measured it by tying it to a string and seeing how long it took to go around a circle of set radius).
    Look at this
    http://www.instructables.com/id/Fifteen-Minute,-Self-propelled-hovercraft/
    If you do it well it will work on calm water too :D
    I think I might make a remote controlled one of these now...
