Boat
Discussion in 'General Electronics Chat' started by kammenos, Jun 3, 2009.
  1. kammenos
    Thread Starter Active Member
    Aug 3, 2008
    127
    I am making a boat, 1 meter long (approx)
    For propeller i want to use a semi-merged (arneson-like) 6 fin surface propulsion system. I gave this fancy title to the hacked 50mm fan that i will use for this reason not to sound "cheap".
    But i need a motor. A 9-12V (better 12V). DC around 1100rpm would be nice.
    Any vendor?
  2. Externet
    Nov 29, 2005
    780
    58
    A heater blower fan from an automobile wreckyard should work fine. With reduction gear, an electric window lifter motor. Or a radiator cooling fan...
    Even a 120VAC vacuum cleaner salvaged motor will be fine for low rpm at 12V; or a rechargeable drill; it has reduction gears or even speed control. There is always one with dead batteries somewhere waiting for you. A 12V car vacuum cleaner...
    Many, many cheap sources.
    Miguel
  3. kammenos
    Aug 3, 2008
    127
    lol! Thanks!
  4. Bernard
    Aug 7, 2008
    4,241
    415
    How much power do you need? Model aircraft / model cars, have wide variety of electric motors available, in brush or brushless, 80+-W to 2200W, straight or gear reduced, from ?$20 to cant afford. With push toward brushless, might find used brush type at a hobby store.
    Example: www.maxxprod.com ;E-fliteRC.com
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    1100 RPM will cavitate like crazy. The bubbles will eat the blades off. Propellers in water are limited to lower speeds, but I'm not sure of the limit for small blades. Think more like 300 - 350 RPM.
  6. kammenos
    Aug 3, 2008
    127
    300-350? That low rpm? Wow! I Knew that cavitation is a problem but i thought that a model 45cm propeller would not have problem with this.
    I checked some at ebay but i found water cooled ship motors and air cooled plane motors. Water cooled are out of the question. The air cooled motors (that have very high rpm) is possible to work for the ship? I mean, is there a problem if they do not have tons of air flowing from the plane nose?
    Bernard: I do not know how to calculate the power that i will need. It's a ship, not heavier than 3-4 kilos (due to the batteries), not longer than 1 meter, not wider than 35-40cm.
  7. KL7AJ
    Nov 4, 2008
    2,047
    295
    Edmund Scientific sells a "bag of motors" for about 5 bucks.
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Gee, Beenthere - I think you're thinking about propellers for aircraft carriers or battleships, in which case you'd likely be right.
    Dad's old Evinrude 25HP outboard would spin the prop at up to 5,500 RPM (max @ WOT).
    Some model gas (fuel) engines run at up around 30,000 RPM, and people use them with a direct drive. :eek:
    Just a guess here, but I think the major limiting factor is the speed of the prop tips, with blades being razor-sharp a close 2nd.
    This page has some useful tips: http://findarticles.com/p/articles/mi_qa3918/is_200012/ai_n8912069/
  9. kammenos
    Aug 3, 2008
    127
    Golly! I thought that the prop would be the easiest. Actually, i did not think of it at all.
  10. Bernard
    Aug 7, 2008
    4,241
    415
    Guestimate on motor power: My Pitman Panther Mod. 9001B model boat motor maesures about 15W, was for a 24 in. submarine[1961], wild guess 50- 75W would do. Your boat sounds like a tug, or shrimper? Not planning on getting it up on a step?? Battery motorcycle 12V lead-acid, 5Ahr?? Was looking in Am. Sci & Surpluss, www.sciplus.com where I [10 years ago ] found a neat Johnson, Chicom, 12V ,4A motor, and see windshield wiper motor, 12V @ 3.5A, about right size. [2005 cat.]
