I have 2 engines, so 2 ignition switches and one wiper timer circuit.
I want to power the circuit board with either ignition on switch.
I want the one timer board to power up 3 wiper motors, each motor draws 1.5 amps.
I was thinking to do this with diodes.
I tested with 5 amp diodes and they power the wiper motor fine.
So it will be three 5 amp diodes on the relay going to each wiper motor. The on pulse from the timer circuit is short duration from 3 to 30 seconds, so diodes are not continuously powering the wiper motor.
The timer circuit simply sends a momentary power pulse to the wiper motor.
The motor has internal switch run off the gear, so the momentary power pulse bumps the the motor past the cam on the gear and the motor is powered by a second wire, this is part of its normal typical self parking design.
So for powering the circuit board, have a diode in each 12vdc wire coming from each switch into the circuit board.
This way turn on either ignition switch will send power to the board, and block power from turning on the other engines ignition.
How much power will this circuit consume? Think a small 1 amp diode will work?
