Yes, it just removes all the loads apart from rotation from the servo, which helps protect it from damage and makes it easier for it to turn.Ouff....sounds like lots of work this arm...
yep standard hi-teck servo...it should fit and if it doesn't I'll have one made here...
so if I get you well its purpose is to have the weight of arm Not crushing the motor, huh? sorry if ima bit slow understanding...I'm actually studying for my exam on monday and take a look here now and then...
Ima try to order that too...hope i still have some cash... LOL....
But I'm a bit scared...hope I'll have everything on time...
Thanks!
I couldn't find anything similar on ebay.
There are a lot of ball bearings on their own on ebay, but it is pretty hard to make the mounting and the shaft through the centre.
An option would be to find something that already has a shaft like this:
http://www.ebay.co.uk/itm/Shimano-B...sure_cycling_bikeparts_SR&hash=item4164ec8764
Probably better to find one nearer you if you are going to do that.
They are also pretty massive, maybe there is a better option.
You could attach the body to the base, make a little adapter for the servo (could just be a metal plate with holes drilled to match the servo horn) and mount the arm to the other end.
