I just designed a 8051 mini-computer circuit and I was about ready to do the second side of a double sided board. I discovered at that point when the holes did not match up, that I printed out the transparencies in the wrong orientation. this means that the circuit will not work even if I continued to proceed with it.
so before I make the same mistake again and again of using improper orientation/mirroring, is there any simple steps someone can point out to me that maybe I should be following so that a lightbulb can go off in my head when I print the circuits of both sides out?
I just wasted a $15 circuit board, some etchant, and some developer solution for nothing.
thanks.
thanks.
