bluetooth
Discussion in 'Wireless & RF Design' started by david2488, Mar 22, 2011.
  1. david2488
    Mar 3, 2011
    why bluetooth is not operated at low frequency, since low frequency has large wavelenth ,can travel more distance and power requirement will also be low .;)
  2. retched
    Dec 5, 2009
    5,201
    313
    You need a larger antenna for a larger wavelength. Do you want a 15 foot antenna hanging off your ear? ;)
  3. PRS
    Aug 24, 2008
    989
    35
    Why not modulate the lower frequency signal onto the higher frequency signal? This question applies to all communications. Hi frequency requires line of sight, but low frequency bounces off the ionosphere. Why not take advantage of the latter in any case that is practical?
