I want to connect a sensor to a data aquisition device which will then relay the received signal to a microprocessor using bluetooth. Could someone suggest a simple and inexpensive data aquisition device which will store the value. It should have bluetooth capabilities for me to transmit the signal to a microprocessor. Also, some info on an inexpensive bluetooth device would help.
Thanks.
Thanks.
