Bluetooth range doubt
Discussion in 'Wireless & RF Design' started by krow, Dec 19, 2011.
  1. krow
    May 25, 2010
    49
    I'm new to Bluetooth technology, I wonder what's the best (or correct) way to find the range of a Bluetooth module when, for instance, we have a laptop and cellphone.
    Let's say I'm holding my cellphone and I want to know how far I can walk away from the laptop without losing the connection between the two devices, do I just walk away from the laptop until I don't see any data or is there an accurate and mathematical method to find that out? I'm totally new to this, please don't laugh at my question, thanks a lot for clarifying this.
  2. K7GUH
    Member
    Jan 28, 2011
    191
    23
    If you had an accurate way to measure transmitter output and receiver sensitivity, you could make a reasonable calculation with the inverse square law. However, the time honored method of experimenting with a short walk is likely more relevant, if not strongly recommended.
  3. KJ6EAD
    Apr 30, 2011
    1,426
    363
    Bluetooth technical standards may specify a limit defined by a data throughput requirement or a maximum error rate limit. Why not look up the standards and see?
  4. krow
    May 25, 2010
    49
    Hey guys, your two answers pointed me in the right direction, thanks.
