Bluetooth motor control
Discussion in 'The Projects Forum' started by JMDesign, Jul 16, 2013.
  1. JMDesign
    Jul 16, 2013
    Good evening
    My name is Jeff. I'm look for some help in designing a Bluetooth motor controller. this would have to be an add on to a main board i have already designed. I am running a 48 volt system. I am also using aTPM400 motor control. My current main board uses a pic micro to a handheld using a CAT5e cable. I am also in the works of remodeling the current mainboard and would like to add the bluetooth part to the new board. What I need.
    To be able to change speed/direction (ramp up, ramp down)
    To have a fail safe in case you lose signal ( C Code ) - Can build later
    Any help would be greatly welcomed.
