Bluetooth module for microcontroller.
Discussion in 'Embedded Systems and Microcontrollers' started by micro-charger, Jan 24, 2011.
  1. micro-charger
    Jan 24, 2011
    I am working on a project which requires uC with bluetooth module (as well as wireless adapter too). can someone suggest affordable uC with these functionalities??
    Thanks in advance... :)
  2. Arm_n_Legs
    Mar 7, 2007
    183
    10
    I think most bluetooth modules can communicate with the uC through some standard interface such as RS232, SPI, etc. I am using the bluegiga WT-11 and am communicating with it through the RS232 port of my uC.
  3. aegistalons
    Member
    Feb 12, 2011
    32
    I'm also interested in this. I did a quick search on the Bluegiga WT-11, and it goes for about $30 on Mouser. Does anyone know of an IC that you can buy that does all the bluetooth and maybe you can just add an antenna on to the board you are developing. I'm thinking of something that you would typically find in bluetooth headsets, like the ones you can grab for $10.
