Blue Tooth Help!
Discussion in 'General Electronics Chat' started by RiehlDesigner, Aug 4, 2015.
  1. RiehlDesigner
    Aug 4, 2015
    Hi, so I would like to develop a board that when a button is mechanically pressed (switched) it relays a signal to my cell phone allowing me to find it. Therefore on the phone end I would harness this signal to emit a light or sound. Anyone have any Blue Tooth experience they could shed on me? I am a university student working on a homing device for a small research product.
    Thanks!!
  2. joeyd999
    Jun 6, 2011
    2,756
    2,916
  3. joeyd999
    Jun 6, 2011
    2,756
    2,916
    And, what happens when you lose the 'homing device'?
  4. RiehlDesigner
    Aug 4, 2015
    What if I'm home alone! Basically I need help on using a blue tooth module to communicate with my smart phone.
  5. mcgyvr
    Oct 15, 2009
    4,784
    973
    Just a FYI..
    Google Android Device Manager will find/ring your phone from anywhere in the world
    Apple Icloud has the same functionality.
    But in general you would need a bluetooth module with button and write all the code to pair/control the phone.
  6. RiehlDesigner
    Aug 4, 2015
    Yea basically I just need the function. Not to worry about the application. Just what sort of components would one need on this board.
  7. mcgyvr
    Oct 15, 2009
    4,784
    973
    A bluetooth module with at least 1 I/O channel, button, pullup or down resistors and any other support components for the module..
    Maybe you can proto with this..
    https://punchthrough.com/bean/
  8. RiehlDesigner
    Aug 4, 2015
    Cool thanks! Thats all I thought I would need is something simple.
  9. Lectraplayer
    Member
    Jan 2, 2015
    77
    5
    A Pebble also works... The Dashboard app has a finder function, and if your phone is paired, it will have your phone making noise until you turn it off. It will also tell you things like how much battery and signal the phone has.
