I'm working on a small project which involves an ATtiny controlling 4 LEDs. Luckily, 3/4 are colors that can run with Vf <2.5V but the blue one is being a problem.
I'm considering the following options but I'm not sure which is the best to take:
1.) 3.3V to 5V boost regulator. At my quantities I should be able to get one for ~0.50. This solves the problem but I'm going to have to recklessly burn away the excess with more current limiting than I would running the outputs @ 3V for the other LEDs
2.) Charge Pump. The 555 Timer used for driving a blue LED in this manner in the workbook is excessively costly. I could build a discrete one but I'm worried that with only 2k of program memory left on my micro that I should save the resources. Also, ordering the parts almost makes the boost regulator worth it.
Any input?
Thanks.
Any input?
Thanks.
