Block Diagram
Discussion in 'Homework Help' started by TimeZero, Oct 3, 2015.
  1. TimeZero
    Sep 14, 2015
    18
    hi
    I did this problem
    my solution right?
  2. MrAl
    Distinguished Member
    Jun 17, 2014
    2,555
    515
    Hello there,
    I just looked at your first and second diagrams and it looks like you are doing it right, although i have not checked your entire solution. You can look up Masons Gain Formula to get a second technique for doing this which will allow you to check your own results. For the way you did it, it looks like when you move a pickoff point you adjust the path transmittance accordingly, but having that second method of calculating the solution means you'll always be able to check your own results, even on a closed room test where you can not ask for opinions on your results.
    BTW showing your progression of transformations rather than just one entire complete transformation is a very good idea, which allows someone else to follow your work much easier and thus faster.
    TimeZero likes this.
