1. hindiikawayos
    Jun 8, 2011
    40
    hello!
    how to remove rubber coupling from shafting? (osterizer blender 4172). tnx:confused:
  2. KJ6EAD
    Apr 30, 2011
    1,426
    364
    There may not be a non-destructive way to do it. I believe the rubber is molded over a metal framework and the blade shaft is peened at the blade end to complete the assembly.
  3. hindiikawayos
    Jun 8, 2011
    40
    Thank you!
    how to replace the bushing?
  4. KJ6EAD
    Apr 30, 2011
    1,426
    364
  5. hindiikawayos
    Jun 8, 2011
    40
    yes. thats the rubber coupling. i wander how to remove that from the shafting so that i can pullout the rotor together with the shafting?
  6. KJ6EAD
    Apr 30, 2011
    1,426
    364
    It's threaded so there may be some wrench flats on the shaft below it.
  7. hindiikawayos
    Jun 8, 2011
    40
    what kind of tools do i need to remove the rubber coupling from the shafting? thank you.
  8. shortbus
    Sep 30, 2009
    4,098
    1,700
  9. hindiikawayos
    Jun 8, 2011
    40
    Thank you very much. I'll try to do it...
