Hello all,
I am using BLDC micromotor from Saeshin
it RPM range is 500 to 35000
torque = 4Ncm
I am using 1KHz PWM waveform with variable duty cycle from microcontroller and giving to motor driver IC
L6205 and at the OUT pins of the L6205 motor is connected
Can you tell me the relation between PWM and RPM. suppose I want to generate 5000 RPM then what setting in RPM I should do?
Regards
torque = 4Ncm
Regards
