bldc motor speed control
Discussion in 'The Projects Forum' started by jim2618, May 21, 2014.
  1. jim2618
    May 21, 2014
    8
    i need to control the speed of bldc motor ...the motor is without sensors.. i m using arduino mega 2560 for pwm.. i need an alternative circuitry for electronic speed controller.. help plzz.. m stuck up:(
  2. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    What motor size/details? Can a RC EMC controller be used?
    Max.
  3. jim2618
    May 21, 2014
    8
    motor is KDA-20-22L it has peak current of 18 amps ..dont knw abt rc emc controller !! i think three phase bridge invertor circuit is to be made...
  4. jim2618
    May 21, 2014
    8
    but still there is no clear picture how to start.. for reference purpose the motor,s speed is controlled by using esc but it was only a reference work !! the main problem is to make an alternative for it..jim
  5. enggricha
    Member
    May 17, 2014
    62
    I think Max was referring to an RC ESC... i would recommend the same too, if you do not have any 3phase design experience. RC ESCs mostly have a AT Mega controller on them that can be reprogrammed, that way u can use ur own firmware and not bother about doing the design urself. BTW if u want a sensorless control then u should be looking elsewhere.
  6. jim2618
    May 21, 2014
    8
    yes i am looking for senserless approach but where to look that is the problem in which i am stuck up
  7. jim2618
    May 21, 2014
    8
    it is the requirement of the project that alternative is required !! ESC,s are easily available we need to make our own circuit bro
  8. enggricha
    Member
    May 17, 2014
    62
    If you are planning on a fresh design, then it depends on lots of factors ...mainly ur experience in the area..
    http://www.ti.com/lit/an/slaa503/slaa503.pdf
    this is a ti app note, which covers the basic ingredients. You can start with this.
    BTW not a "bro" here
  9. jim2618
    May 21, 2014
    8
    ok dude its fine now i think
  10. jim2618
    May 21, 2014
    8
    this was sensored man !! told ya i need sensorless approach !! this help i can get from google as well but blogs contain more information than this
  11. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    Yes the RC ESC are sensorless as is the large higher voltage Fisher & Paykel motors used in washing machines.
    The RC are typically very large currents for short periods, 20A is typical for e.g.
    Have you searched the app notes of IR., Freescale, Picmicro etc, there are quite a few sites to glean info from, but the majority of BLDC motors are commutated, (sensored).
    Max.
