Hi, I'm new here but have lurked around for answers before.
My question is with regards to a BLDC motor I plan to use and how I could implement both regenerative braking and the ability to use it as a full on generator to charge the power supply. Correct me if I'm wrong but I believe they are different (the regenerative braking of a brushed motor from my understanding uses the PWM switching as part of a boost converter, to be used as a generator I believe it would have to be spun faster than the power supply would make it spin in order to generate a voltage high enough to recharge it.
I've had ideas (mostly on paper, circuit diagrams as such) but don't have the things to test them right now or they seem to be flawed. Originally I thought of hooking the terminals of the coils on the motor up to rectifiers but I think this would effectively give me a short. I drew a little diagram:
Description:
-L1 is the motor coil, T1 is the transistor/mosfet ill use to switch it on/off.
-d1/d2 are the rectifier diodes and C1 is the capacitor to smooth out the voltage signal (not sure if C1 is necessary, please tell me if you happen to know)
-L2, T2 and d3 make up the boost converter to increase the voltage to let me recharging the power supply.
I know its missing some diodes across the transistors etc but this is more of a concept than anything. Anyways the problem I see is that wouldnt current just flow through the loop indicated by the arrow and ignore the motor? I've been googling for answers to BLDC motor regenerative braking and havent really found an answer I can understand, this is what I've managed to piece together from that research.
My main questions are: am I horribly off and on the wrong track? Do I need the boost converter there (some circuits I've seen don't include one)? Would the motor coil by bypassed like I think it will?
Thanks in advance for any help.
Description:
