I have a project of building a sensorless Electronic Speed Controller for Brushless DC Motor. I first made a research to understand how does the electronic components work , how does the motor work and to know some methods that allow controlling these motors. Then, I made a circuit on a solderless breadboard, and wrote the code and after testing on an HDD brushless motor and finding problems on the circuit or on the code, and after solving these problems, I was able to make an HDD brushless motor turn with a variable speed, and the ESC worked. The problem is that the motor doesn't start turning untill I raise PWM duty cycle to 60%, can someone explain me why?
Thank you
Thank you
