BLDC as generator drops current
Discussion in 'General Electronics Chat' started by flyinglawyer, Feb 1, 2015.
  1. flyinglawyer
    Feb 1, 2015
    I am making a winch that will spool out line under tension. I've had success using an old brushed motor. I short the windings, so that when I unspool the line, the motor provides braking torque and line tension. The old motor is not powerful enough, so I upgraded to a stronger, brushless motor with 5000w power rating.
    Here's the problem: as I unspool the line from this motor, it builds torque until it reaches a certain value (130lb in my case), and then the current and torque suddenly drop to zero and then build up again, then drop again.
    The motor has 3 phases (which are shorted for the generator mode) and a 5-pin hall sensor connector (unused here). Here's the exact motor: http://www.aliexpress.com/item/Elec...-bicycle-5kw-ebike-hub-motor/32234157960.html
    Why is it dropping the current in generator mode? Do these motors have some kind of a built-in internal protection? I thought that there was nothing inside but windings and magnets (and halls), as this one uses an external 100Amp controller.
    Any thoughts would be appreciated.
    PS. Does this 3-phase brushless generate AC or pulse DC?
  2. kubeek
    Sep 20, 2005
    4,689
    806
    Could it be the controller cutting out?
  3. flyinglawyer
    Feb 1, 2015
    The controller is disconnected.
