BK Function Generator question
Discussion in 'General Electronics Chat' started by park1231, Jul 24, 2010.
  1. park1231
    Jul 24, 2010
    I just purchased a used BK 4003A function generator. Everything is working fine but I have noticed that there is an area about the diameter of a red bull can on the top right side of the case that gets hot to the touch. It is not so hot that I cannot maintain skin contact. There is a brownish discoloration about the size of a quarter on the exterior of the case above that point.
    Is this normal heat from the power supply or is it something that I should be worried about?
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    It is probably nothing, I'm betting this function generator has an internal power supply, which means it has a spot where the excess voltage is dumped as heat. If it is very old at all (which it probably is) this heat will discolor the plastic.
    If in doubt you could open it up and take a look see.
    http://www.testequipmentdepot.com/b...ors/4003.htm?gclid=CLucivzMhaMCFQG3sgod8QKTaw
    There is supposed to be a manual available at the above site.
  3. park1231
    Jul 24, 2010
    Yes, it does have an internal power supply. Thank you for the quick response.
  4. someonesdad
    Jul 7, 2009
    1,585
    141
    Unfortunately, the B&K manuals never tell you anything about the internal construction and schematics are rare if they are not nonexistent (I've looked at most of the current B&K manuals and I don't remember seeing any schematics).
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You might have a "leaky" capacitor in the power supply section. That would cause excess heating.
    Posting high-res photos of that area would help to figure out what the problem might be.
