BJT's
Discussion in 'General Electronics Chat' started by elly0007, May 7, 2009.
  1. elly0007
    May 7, 2009
    I have a problem , how to explain a certain graph....
    i have a circuit of an NPN CC BJT with PNP diode-active load ... and the graph came from o V- 0.7V not a straight line its curved like and exponential graph . then after this region both Vin and Vout are linear (ie straight line is obtained ) ... can someone please explain how this graph is obtained , and which part is the active region and cutoff region.???
    thanks
    elly
  2. Ron H
    Apr 14, 2005
    7,050
    657
    You need to post the schematic and the graph.
  3. elly0007
    May 7, 2009
    i attached the graph and the schematic ..
    thanks
  4. Ron H
    Apr 14, 2005
    7,050
    657
    Is the horizontal axis a sweep of V1?
  5. elly0007
    May 7, 2009
    it is Vin against Vout .. Vin = (Vdc = 1.85)
