BJT's Saturation Region
Discussion in 'Homework Help' started by khiawyen, May 5, 2009.
  1. khiawyen
    Nov 17, 2008
    Vce < Vbe will cause a BJT to be in saturation mode. How is it possible that Vce < Vbe will forward bias both the PN junction in a NPN transistor?
  2. mik3
    Feb 4, 2008
    4,846
    63
    If Vbe is about -0.7V and Vce is about -0.3V then the base-collector diode (NP) will be forward biased. The collector is more positive than the base.
  3. steveb
    Jul 3, 2008
    2,433
    469
    Vbe+Vcb=Vce, hence Vbc=Vbe-Vce
    As an example, if Vce=0.2 V and Vbe=0.7V, then Vbc=0.5V which is forward biasing of the base-collector junction.
  4. steveb
    Jul 3, 2008
    2,433
    469
    mik3,
    Did you misread his post and think that he said PNP transistor?
  5. mik3
    Feb 4, 2008
    4,846
    63
    Yes! :rolleyes:
  6. Darren Holdstock
    Feb 10, 2009
    262
    11
    When Vce < Vbe a chunk of the collector current flows back through the base, which is one of the reasons why a transistors gain is so low in the saturation region.
    There is no universally agreed definition of saturation - Vce < Vbe is as good as any; another popular rule of thumb is Ic <= 10xIb.
