BJT
Discussion in 'General Electronics Chat' started by Varsha, Dec 22, 2008.
  1. Varsha
    Nov 17, 2008
    14
    hello
    What is the application of the bjt in inversion mode, that is emitter base reverse biased and base collector forward biased.
    Thank You
    Varsha
  2. denki
    Sep 15, 2008
    i believe that's called "reverse active" and is basically the same as forward active, though you wont get the same performance due to the asymmetric doping profile.
  3. Varsha
    Nov 17, 2008
    14
    so, is there a specific application with the bjt in this reason like in active region you have amplification and between cutoff and saturation as switch
  4. kathapurushan
    Member
    Dec 17, 2008
    14
