BJT voltage gain
Discussion in 'Homework Help' started by hamza324, Jul 10, 2011.
  1. hamza324
    Jul 10, 2011
    33
    hi ....
    I was reading through my book and could understand the difference between "terminal voltage gain" and "overall voltage gain"
    BJT single stage amplifiers
  2. Jony130
    Feb 17, 2009
    3,993
    1,116
    Can you show as the diagram or the text from that book.
    General speaking when we treat the amplifier alone the the voltage gain is equal
    Av = Vout/Vin
    But if we consider the influence of the source resistance and input resistance of our amplifier we get the overall gain.
    Overall gain = Vout/Vs = Vin/Vs * Vout/Vin = 0.5 * 100 = 50V/V
      File size:
      6.6 KB
      148
    anhnha likes this.
  3. hamza324
    Jul 10, 2011
    33
    Thanks...it was helpful
  4. lazukan
    Mar 29, 2011
    5
    terminal voltage gain refers to V (collector ) / V ( base)= Beta
    Overall voltage gain refers V ( out) / V( in)
    It is the matter of the fact that at which terminal or branch you take the measurements
    Correct me if i am wrong
    Lazukan
  5. RLC
    Jul 20, 2011
    13
    Terminal gain refers to β gain (Hfe) which we can directly measure on
    Multi-meter.
    While overall voltage gain refers to, taking gain with taking source Impedance and Load impedance into consideration
  6. Adjuster
    Dec 26, 2010
    2,147
    300
    β is a measure of current gain: it is not directly related to voltage gain, although due to its effect on input impedance it does make a contribution to overall voltage gain.
    RLC likes this.
  7. RLC
    Jul 20, 2011
    13
    yeah ur right i realized my mistake
    Thank u:D
