BJT transistor analysis
Discussion in 'Homework Help' started by PsySc0rpi0n, Apr 30, 2015.
  1. PsySc0rpi0n
    Mar 4, 2014
    1,191
    Hi everyone...
    I need to calculate the Ic for the attached circuit, using Thevenin method!
    β=167.1
    Vcc = 20V
    R1 = 160kΩ
    R2 = 40kΩ
    Re = 1kΩ
    I'm calculating Vth = (40/(40+160))*20 = 4V
    Then Rth = (160*40)/(160+40)=3.2kΩ
    Then using input net (base net) I'm calculating Ib as:
    Ib = (Vth - Vbe)/(Rth + Re(β+1)) = (4-0.7)/(3.5k+1k*(167.1+1))=19.26μA
    Then using Ic = β*Ib = 167.1*19.26μA = 3.22mA but the correct result is 2.75mA... Can't figure out where am I going wrong!
    • aac.asc
      File size:
      722 bytes
      7
      File size:
      4.7 KB
      22
  2. ericgibbs
    Jan 29, 2010
    2,590
    390
    Morning psy,
    What type of BJT circuit would you say that you have posted.?
    E
  3. PsySc0rpi0n
    Mar 4, 2014
    1,191
    Voltage divider biased transistor... Is this what you're asking
    edited;
    Ok, I got it.
    I was wrong calculating Rth. It's not 3.2kΩ, but 32kΩ.
  4. PsySc0rpi0n
    Mar 4, 2014
    1,191
    I have another problem... This time is with LTSpice.
    I'm trying to simulate the attached circuit but it is taking for ever to finish the simulation.. Why?
    • aac.asc
      File size:
      733 bytes
      6
      File size:
      75.5 KB
      12
  5. ericgibbs
    Jan 29, 2010
    2,590
    390
    No ground reference.!
  6. PsySc0rpi0n
    Mar 4, 2014
    1,191
    OMG... But LTSpice usualy complains about it. But didn't do it this time! Bahhh... Thanks!
  7. PsySc0rpi0n
    Mar 4, 2014
    1,191
    Ok, if I want to write the 2 nets (input and output), can I write then like this:
    Net 1 - Input net
    Vcc = R1(Ic+Ib) + Vbe + Vγ
    Net 2 - Output net
    Vcc = R1(Ic + Ib) + Vce + Vγ
    Are these 2 equations correct?
  8. ericgibbs
    Jan 29, 2010
    2,590
    390
    Is this post #4 circuit.? and what is vy.?
  9. PsySc0rpi0n
    Mar 4, 2014
    1,191
    Yes it's about post #4. Vγ is the LED voltage. I think it's called forward voltage, right? Let's consider the following values:
    R1 = 2.1kΩ
    Vcc = 12V
    hFE = 119
    We are asked to find current at R1.
    So, I'm doing:
    Ib = (12-0.7-2.5)/(2.1k*(1+119)) = 34.92μA
    Vce = 12-2.5-2.1k*(34.92μa+34.92μA*119)=0.721V
    Ic = 119*34.92μA = 4.155mA
  10. ericgibbs
    Jan 29, 2010
    2,590
    390
    Looks close enough to me.
    Have you checked it using LTSpice.?
  11. PsySc0rpi0n
    Mar 4, 2014
    1,191
    Not yet checked with LTSpice...
    The problem is that the answer should be 4mA.
    This is a question that our tutor posts in our school's site (quizz) and that we must answer to it within a given deadline. A friend of me helped me and we have calculated a value of 4mA sharp and the quizz "told me" the 4mA values was correct.
    But current across R1 is Ib + Ic. So it should be greater than 4.155mA, but the quizz said that 4mA was correct!
  12. ericgibbs
    Jan 29, 2010
    2,590
    390
    LTSpice shows
    Ib=37uA
    Ic=4.39mA
    Vbe = 0.694V
    Ve=2.09V
    Vce=0.694V
    Please post your calculation showing the Ic as 4.0mA
  13. PsySc0rpi0n
    Mar 4, 2014
    1,191
    I can't find them in the calculator... probably the screen "run out" of memory to store the calculations history and deleted the oldest calcs I made. And I can't remember the values of R1, Vγ and hFE.
    Every time we attempt to answer the quizz, these values changes!
    Anyway, the most important was to know that the net equations I wrote were correct! The rest is math that the calculator does!
