BJT small signal analysis without beta???
Discussion in 'Homework Help' started by Synia, Aug 25, 2011.
  1. Synia
    Aug 25, 2011
    Hi all
    I am currently working on a question that states, for a BJT similar to the one below,
    If all thats given is:
    vc = 5V
    ve = 4V
    vb = 4.7V
    ie= 10uA
    Is there a way to calculate what R1 and R2 are? Without β being given?
    It would be great if anyone can help, i've been stuck on it all night! And is beginning to suspect the question is wrong...
  2. MrChips
    Oct 2, 2009
    12,623
    3,451
    This is a common collector a.k.a. emitter follower configuration.
    Try writing out the equations using variables for Re and beta. Ignore R1 and R2.
    You will probably find that the voltage gain is unity.
    (With the information supplied you can determine Re.)
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    I'd be surprised if ie (Ie?) is actually 10uA ....
    What is the actual problem asking you to solve?
  4. jp1390
    Member
    Aug 22, 2011
    45
    For this case, the BJT is in forward-active and there should be little current pouring into the base, relative to Ie and Ic.
    With that being said, it would be a fair assumption that R1 and R2 create a voltage divider, with the current flowing through both resistors being significantly larger than the base current.
    We know that Vcc = 5 V and Vb = 4.7 V:
    Ratio = \frac{V_{b}}{V_{cc}} = \frac{4.7}{5} = 0.94 = \frac{R_{2}}{R_{1} + R_{2}}
    Rearranging:
    R_{1} = \frac{R_{2}(1 - 0.94)}{0.94} = 0.06*R_{2}
    From here you can just pick a value for R2 and you will get your R1 value. This choice also determines the current flowing through them, so make sure that it is not too small as compared to the base!
  5. Synia
    Aug 25, 2011
    Thank you for all your answers
    This is actually part of a low voltage FM radio transmitter design i have been given to do. The voltages and current are worked out by my partner from other parts of the circuit, and i am currently just trying to find what value to put into R1 and R2 that the circuit work properly....
    @jp so how do i work out how much current is flowing into the base?
  6. jp1390
    Member
    Aug 22, 2011
    45
    Well normally beta is between 40 - 100 for general purposes, so pick a value within that range and you can figure out the base current. From there you can figure out how large R1/R2 have to be in order to have the base current negligible to the current through R1/R2.
  7. hobbyist
    Distinguished Member
    Aug 10, 2008
    773
    62
    Is your RE value around 400K ohms?
    To give 4v. @ 10uA. for IE.
  8. PRS
    Aug 24, 2008
    989
    35
    Re-check your parameters. Ie = 10uA is ridiculously low.
