BJT quirks
Discussion in 'Feedback and Suggestions' started by Unregistered, Nov 7, 2009.
  1. Unregistered
    Thread Starter Guest
    Two typos in BJT quirks.
    If two identical power transistors were paralleled for higher current, one would expect them to share current equally. Because of differences in characteristerics, transistors do not hasre current equally.
    Probably should be "shared".
    The solution to the junction capacitance problem is to select a high frequency transistor for wide bandwidth applications— RF (radio frequency) or microwave transistor. The bandwidth can be extended further by using the common-base instead of the common=emitter configuration. The grounded base shields the emitter input from capacitive collector feedback. A two-transistor cascode arrangement will yield the same bandwidth as the common-base, with the higher input impedance of the common-emitter.
    Needs "-" rather than "="
  2. Dcrunkilton
    E-book Co-ordinator
    Jul 31, 2004
    416
    11
    Thanks for the corrections. I will post back when this is uploaded to ibiblio.
  3. Dcrunkilton
    E-book Co-ordinator
    Jul 31, 2004
    416
    11
    I have updated the ibiblio copy for numerous corrections (not just for this thread) over the last few days. The list of affected files and images follows:
    DC V1:dcmeter.sml contrib.sml 00502.png
    AC V2:basicac.sml contrib.sml
    Semi V3: bjt.sml diode.sml contrib.sml theory.sml 03288.png 03304.png 03392.png
    Digital V4: boolean.sml contrib.sml
