BJT project - question
Discussion in 'Homework Help' started by ibm123, May 13, 2009.
  1. ibm123
    May 13, 2009
    17
    i made a project with BJT NPN
    now for some reason the Ic and Ib are ok and positive but the Emitter current is ok but negative
    anyone can explain me why is it negative and how can i fix it...
  2. t_n_k
    Mar 6, 2009
    5,448
    783
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    But you can't see the entire schematic!
  4. ibm123
    May 13, 2009
    17
    ok.. hope now its okay
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    Is this your first OrCAD simulation? If not, have you seen this problem before?
    If there are inbuilt example circuits, do they show a similar behavior?
    Perhaps there is a simulation option setting that needs attention?
    I've never used OrCAD so I've no obvious answers.
    Have you checked the OrCAD community forums web site?
  6. mauro.laurenti
    May 8, 2009
    68
    it's normal the behavior you found.
    Just change the transistor with a node.
    ...if all the currents where positive where the electrons can get out?
    ...what ever get inside a node need to get out...
    Something will be positive and something most be negative (independently of what positive and negative means)
    The water from the sink that flow in the hose will get out from the other side...
    Ciao,
    Mauro
  7. ibm123
    May 13, 2009
    17
    its not my first simulation
    it is an inbuilt example circuits but the behavior is not similar..
    actually the current in the Emitter need to go down.
    but the spice shows it as - i want it to show it with a + sign
    the base and collector current need to get inside the transistor and go out from the emitter
    anyone ?
  8. mauro.laurenti
    May 8, 2009
    68
    Check the node below the transistor...and the output current that goes down to the mirror...it's positive...which is what you want.
    I would assume that the current sign is related to the node...
    For the current is the sum that should bother you and not the single sign...
    Ciao,
    Mauro
  9. mauro.laurenti
    May 8, 2009
    68
    ...I want to tell you more...
    For instance with LTspice if you turn the resistor the current within it changes sign...which is strange...
    ...but the sum is always correct...
    Ciao,
    Mauro
  10. ibm123
    May 13, 2009
    17
    its only a sign..
    but still annoying :)
    thanks
  11. mauro.laurenti
    May 8, 2009
    68
