BJT NPN pull-down Resistor
Discussion in 'Homework Help' started by wuz, Jul 8, 2011.
  1. wuz
    Oct 4, 2010
    8
    Hi, I know that it's good practice to include a pull-down resistor R2 between the base - emitter junction to make sure that the transistor remains off when small leakage current is present, and understand that it has to be much larger than the base resistor R1, but I don't fully understand the effect of adding R2 to R1.
    When calculating the base current, are R1 & R2 in parallel? E.g. if Vcc = Vin = 5V, R1 = 1K, R2 = 10K.
    Is it correct that the input impedance = (1/R1+1/R2)^(-1) = 909, so Ib = 4.3V/909 = 4.73mA? So if we have a smaller R2, it's effectly reducing the base current?
    Thanks!
  2. Jony130
    Feb 17, 2009
    3,993
    1,116
    You are very close to the right answer.
    You can use the Thevenin's theorem to find Ib current.
    For example Vin = 5V and R1 = 1K, R2 = 10K we have
    Vth = R2/(R1+R2) * Vin = 4.5V
    And the base current is equal
    Ib = (Vth - Vbe) / R1||R2 = (4.5V - 0.6V) / 909Ω = 3.9V/909Ω ≈ 4.3mA
    anhnha likes this.
  3. wuz
    Oct 4, 2010
    8
    Hi Jony130,
    Thanks very much for your reply. I still don't quite understand how you got 4.3mA from the Thevenin's theorem, and what 2 points you are using for Vth (is it between b & e)? Could you please show me your Thevenin equivalent circuit?
  4. Jony130
    Feb 17, 2009
    3,993
    1,116
    Sure I can show you.
    We replace this part of the circuit ( in this gray rectangle)
    With his Thevenin's equivalent circuit
    Vth = Vin * R2/(R1+R2)
    Rth = R1||R2 = (R1*R2)/(R1+R2)
      File size:
      11.8 KB
      153
    dalam, spark8217 and anhnha like this.
  5. wuz
    Oct 4, 2010
    8
    Thank you for your explanation. It makes perfect sense to me now! I can now go to sleep without feeling confused about the circuit :)
  6. Jony130
    Feb 17, 2009
    3,993
    1,116
    I'm very glad that you can sleep well.
  7. kmohanra
    Feb 4, 2008
    7
    Hello together,
    Can you apply kirchoffs law in the same circuit and explain the base current concept from the Vin.
  8. kkaczor
    Aug 4, 2013
    6
    Could you tell me why we cannot calculate the base current by simple kirchoff's law:
    1. Assume base-emitter voltage drop of 0.7V,
    2. The same voltage drop is on R2, so this means the current which flows through R2 is 0,07mA,
    3. The voltage drop on R1 is 5-0,7 = 4,3V. This gives us the current which flows through R1 of (5-4,3)/1k = 4.3mA
    Finally base current could be calculated as 4,3mA - 0,07mA = 4,23mA
    What I'm doing wrong?
  9. Jony130
    Feb 17, 2009
    3,993
    1,116
    For sure you can use kirchoff's law to find IB current. I don't see anything wrong in your solution.
  10. kkaczor
    Aug 4, 2013
    6
    Okay, but maybe it would be stupid question - why the result values differ?
  11. #12
    Nov 30, 2010
    16,704
    7,354
    Post#2 did not account for the current through the 10k resistor subtracting from the 4.3ma. Your version is right, kk.
    kkaczor likes this.
  12. Jony130
    Feb 17, 2009
    3,993
    1,116
    I assume Vbe = 0.6V and you assume 0.7V
    So for Vbe = 0.6V we have
    IR2 = 0.6V/10KΩ = 60μA and IR1 = (5V - 0.6V)/1KΩ = 4.4mA
    So Ib = 4.4mA - 60μA = 4.34mA
    kkaczor likes this.
  13. kkaczor
    Aug 4, 2013
    6
    I used to assume 0.6V, but I've measured several NPNs yesterday and it does not want to be other than 0.7V.
    Thanks guys for your explanations and help!
  14. Jony130
    Feb 17, 2009
    3,993
    1,116
    This is not true.
    Well its all depend on the Vin value and Rb value.
    I measure Vbe Vs Ib for BC337-40 for Vcc = 10V
    RB = 680kΩ....Vbe = 0.614V....Ib = 13.8µA
    RB = 470kΩ....Vbe = 0.616V....Ib = 20µA
    RB = 220kΩ....Vbe = 0.624V....Ib = 42.61µA
    RB = 100kΩ....Vbe = 0.639V....Ib = 93.61µA
    RB = 50kΩ......Vbe = 0.659V....Ib = 187µA
    RB = 10kΩ......Vbe = 0.719V....Ib = 928µA
    RB = 5kΩ........Vbe = 0.748V....Ib = 1.85mA
    RB = 2kΩ........Vbe = 0.787V....Ib = 4.6mA
    RB = 1kΩ........Vbe = 0.819V....Ib = 9.18mA
    RB = 500Ω......Vbe = 0.856V....Ib = 18.29mA
    RB = 200Ω......Vbe = 0.989V....Ib = 45mA
    KLillie and screen1988 like this.
  15. kkaczor
    Aug 4, 2013
    6
    Vcc was equal to Vin, both 10V?
  16. screen1988
    Member
    Mar 7, 2013
    310
    Could anyone help me explain it?
  17. kkaczor
    Aug 4, 2013
    6
    When you drive transistor from microcontroller for example, when it is starting the state of output pins in unknown and there is a possibility a small current leakage. If so, a small current may drive your transistor.
    To prevent this, you can place a resistor between base and emitter to force current not drive the base, but go through pullup resistor instead.
    screen1988 likes this.
  18. screen1988
    Member
    Mar 7, 2013
    310
    Thanks, kkaczor.
    I have just read that the pull-down resistor is very big (in this case it is much larger than R1). If so, in order for current flows this resistor to ground instead of flowing into base of transistor, we also need the pull-down resistance << input resistance of transistor?
    Is that right?
  19. kkaczor
    Aug 4, 2013
    6
  20. ramancini8
    Member
    Jul 18, 2012
    447
    119
    The calculated 4.5V is actually 4.545V. One writer assumed Vbe=0.6V and you assumed 0.7V. Not theory, just quick, sloppy calculations.
