BJT non inverting switch
Discussion in 'The Projects Forum' started by sarmadhassan, Jun 24, 2013.
  1. sarmadhassan
    Nov 13, 2012
    5
    any one knows that how to use bjt as a non inverting switch to get fixed 5 v at output?
  2. MrChips
    Oct 2, 2009
    12,636
    3,454
    Use the BJT in emitter follower (common collector) configuration.
    sarmadhassan likes this.
  3. crutschow
    Mar 14, 2008
    13,501
    3,375
    What exactly are you trying to switch? Is it a 5V voltage into a load?
  4. sarmadhassan
    Nov 13, 2012
    5
    actually i am making water level controller. and receiving voltage by completing path from water. currently i am getting 3.34 volts on the base from the water. if i take output BJT acts as a inverting switch . but instead when i take output from emitter to behave it as non inverting switch i get the same voltage that is on the base. but i want to have 5v. fixed.
  5. crutschow
    Mar 14, 2008
    13,501
    3,375
    I still don't understand what you are trying to do. Can you post a schematic diagram of what you are attempting?
