BJT Mode
Discussion in 'General Electronics Chat' started by blah2222, Feb 7, 2014.
  1. blah2222
    May 3, 2010
    565
    33
    Quick question regarding modes of an NPN BJT.
    If current is feeding through the base out through the emitter with zero collector current, is the transistor considered to be in the cutoff region?
    Ic = 0
    Ib = 1mA
    Ie = 1mA
    Thanks!
  2. shteii01
    Feb 19, 2010
    3,500
    511
    What does the textbook say?
  3. #12
    Nov 30, 2010
    16,664
    7,311
    That's kind of like, "If the car is rolling downhill, and the transmission is in first gear, but the engine is not running, what mode is that called?" I don't think that is a "mode". Certainly the transmission thinks it is capable of transferring power, but it doesn't have any to transfer. If I had to guess, I'd say it's not in cutoff, but neither is it in the linear region. More like, "What mode is a transistor in if I didn't connect it correctly for any mode?"
  4. alfacliff
    Dec 13, 2013
    2,449
    428
    if the base to emtter is drawing current, the transistor should be conducting. is there anything connected to the collector preferably positive.
  5. blah2222
    May 3, 2010
    565
    33
    Collector is not connected to anything, hence Ic=0.
  6. inwo
    Nov 7, 2013
    2,435
    315
    Starvation mode. I've heard it called.
    Not enough collector voltage.
  7. tindel
    Sep 16, 2012
    576
    196
    You have a diode in that mode...
  8. crutschow
    Mar 14, 2008
    13,475
    3,361
    I agree with tindel. The transistor base-emitter junction is acting as a two-terminal diode. The collector has no effect since it is open.
