BJT Matching?
Discussion in 'Homework Help' started by eng kryptonite, Feb 7, 2010.
  1. eng kryptonite
    Jan 25, 2010
    17
    What degree of matching in emitter area is required for the base-emitter voltages of two bipolar devices with identical collector currents to have a difference of less than 4.6 mV if we use VT = 25.85 mV? How to approach this? Its quite confusing for me. Thanks! : )
  2. mik3
    Feb 4, 2008
    4,846
    63
    What is the related theory behind this question?
  3. Ron H
    Apr 14, 2005
    7,050
    657
    Here is how I would go about it.
    For a given current, the current density is inversely proportional to emitter area. Think of the diode equation and current ratio.
  4. eng kryptonite
    Jan 25, 2010
    17
    If all I have are the VT & the voltage .. how would I go with the diode equation and current ratio? Can you please show some figures so I can follow up or explain a little further? I still don't understand the question :confused:
  5. Ron H
    Apr 14, 2005
    7,050
    657
    Start with diode equations for the two transistor base-emitter junctions:
     I_1=I_s*(e^{\frac{V_{be1}}{V_T}}-1)
     I_2=I_s*(e^{\frac{V_{be2}}{V_T}}-1)
    (Keep in mind what I said previously about emitter area and current density.)
    For reasonable current levels, you can ignore the -1 term in each equation.
    Now, take the natural log of the ratio \small \frac{I_1}{I_2}. (I'm not going to do all the work for you).:)
    You should come up with an equation that contains \small Vbe1-Vbe2. Do you recognize what that difference represents? Plug it and  \small V_T into your equation, then take the antilog. What answer do you get?
  6. eng kryptonite
    Jan 25, 2010
    17
    Thanks Ron .. The idea became much better now and I have came up with a solution thats attached. Nothing brilliant :D but now this thing makes sense to me. Sounds good to you?
    what I got is 1.78%.
  7. Ron H
    Apr 14, 2005
    7,050
    657
    My version of Word won't open your file.
    Your answer is ln(I1/I2). You need I1/I2.
    EDIT: ln(I1/I2)=0.178. Even if this were the correct answer, it is not equivalent to 1.78%.:confused:
  8. eng kryptonite
    Jan 25, 2010
    17
    I know its not 1.78% .. What I got is 0.178e-1 * 100 which gave me that percentage. I converted the doc to word 2003 and it should be okay now. :D
  9. Ron H
    Apr 14, 2005
    7,050
    657
    \frac{I_{s1}}{I_{s2}}=e^{\frac{4.6}{25.85}}=e^{0.17795}
    Are you aware that e = 2.71828..., which is the base for Naperian logarithms?
     \frac {I_{s1}}{I_{s2}}=1.1948
    Since  I_s is proportional to emitter area, then the areas must match within ≈20%.
  10. eng kryptonite
    Jan 25, 2010
    17
    Ooops :D
    I missed out the "e" part :)
    for some reason under all this stress I calculated that as (10^x) ..
    Thanks a lot Ron .. your help is appreciated once again.
