BJT Large Signal
Discussion in 'General Electronics Chat' started by Mazaag, Feb 5, 2008.
  1. Mazaag
    Thread Starter Senior Member
    Oct 23, 2004
    255
    Hey guys
    Is there a value for the large signal resistance from the Collector to the emitter of a BJT ? like i know for MOSFETs there is a large signal Rds, and a small signal ro , what about BJTs ? and how do you calculate this value
    thanks
  2. scubasteve_911
    Dec 27, 2007
    1,202
    BJTs go by a Vce(sat) parameter, which is a very dynamic. It depends very much on current through the transistor and temperature.
    Steve
  3. mik3
    Feb 4, 2008
    4,846
    63
    BJTs dont have a fixed resistance like FETs , it depends upon your circuit.
    You can find it if you devide Vce by Ic for a particular circuit
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    The collector of a transistor is a very high impedance. The circuit's output impedance is just the collector resistor in parallel with the load resistance.
  5. hgmjr
    Jan 28, 2005
    9,030
    214
    Output resistance can be estimated at least for the small signal model by dividing the BJT's "Early voltage" by the collector current. Here is the wikipedia article describing this relationship.
    hgmjr
