BJT High frequency analysis
Discussion in 'Homework Help' started by Digit0001, Jun 2, 2012.
  1. Digit0001
    Mar 28, 2010
    89
    Hi
    Can someone tell me what i have done wrong in the following question?
    The question and my solutions are below:
    View attachment question10.pdf
    The answer is supposed to be fH=2.97MHz
    P.S
  2. Digit0001
    Mar 28, 2010
    89
    so can anyone help me on this question?
  3. Jony130
    Feb 17, 2009
    3,990
    1,115
    Well I don't have a time to do any calculations. But for my in this circuit there is no millers effect.
  4. Digit0001
    Mar 28, 2010
    89
    ok, but from my solutions i have Q1 => C-B and Q2 => C-E is this correct?
  5. Jony130
    Feb 17, 2009
    3,990
    1,115
    Yes Q2 works as a CE amplifier but the gain of this amplifier is close to one.
    And Q1 work as CB amplifier and CB amplifier is free from miller effect
  6. Digit0001
    Mar 28, 2010
    89
    i have worked it out, forgot to use the gain for common emitter in order to work out the miller's effect
  7. t_n_k
    Mar 6, 2009
    5,448
    783
    Interestingly, I've found a more careful analysis / simulation gives the upper -3dB point as ~3.8MHz [rather than 2.97MHz] which suggests the approximations applied aren't particularly robust. The model I used was the Hybrid-Pi. Rather than applying the Miller theorem I left Cμ [2pF] from the two BJT's collector-to-base terminals. Cbe was 5.96pF per the relationship fT=gm/(2∏(Cμ+Cbe). Also used gm=20mA/V and r∏=5k.
