BJT experts answer please...
Discussion in 'Homework Help' started by nPab, Sep 21, 2014.
  1. nPab
    Sep 16, 2014
    5
    The question is to find Ve, Vc1and Vc2 in the circuit below....I have no idea whatsoever on how to begin...please explain step by step...
    Thanks!
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    Notice that Q2 base is connected directly to GND and Q1 base to 0.5V. If we assume that Vbe = 0.7V we immediately see that if we assume that Q1 is ON the Ve voltage must by equal to Vb + Veb = 0.5V + 0.7V = 1.2V and this implies that VebQ2 = 1.2V.
    But you should know that |Vbe| = 1.2V cannot happen without destroying the transistor. This implies that our assumption (about Q1 is turn on) was wrong. From here we see that Q1 is cut-off (VebQ1 = 0.7V - 0.5V = 0.2V) and Q2 is in active region or in saturation. So, now we can easily find all the voltage in the circuit. Can you do it ?
    nPab likes this.
  3. nPab
    Sep 16, 2014
    5
    Got it! thanks loads..:D
  4. KL7AJ
    Nov 4, 2008
    2,047
    294
    Just what I was gonna say. :)
