BJT design question
Discussion in 'Homework Help' started by canon, Nov 14, 2008.
  1. canon
    Nov 14, 2008
    which is the best arrangement for a bjt amplifier​
  2. veritas
    Feb 7, 2008
    167
    by "arrangement" do you mean common emitter vs common base vs common collector? All of these setups have different properties of input impedance, output impedance, and gain. None of them are "best" for all applications, because different applications have different requirements and constraints.
    Improving an amplifier often involves using multiple BJT's to get the better gain, frequency response, and impedances as needed.
    *edit* I suppose I should include sources:
    http://en.wikipedia.org/wiki/Common_emitter
    http://en.wikipedia.org/wiki/Common_base
    http://en.wikipedia.org/wiki/Common_collector
    The AAC section on BJT's is also good for comparing amplifiers
    http://www.allaboutcircuits.com/vol_3/chpt_4/index.html
