BJT current source calculation
Discussion in 'Homework Help' started by athulascc, Feb 24, 2015.
  1. athulascc
    Aug 15, 2014
    88
    here is the problem
    I can analysis it and derive equations and solve for Vc. But I do not need Is , But why they have given it?
    what is Is?
  2. WBahn
    Mar 31, 2012
    18,064
    4,904
    You may not. The information might be a red herring intended to distract you, or it could be necessary for a follow-up question.
    How are you using the temperature information?
  3. athulascc
    Aug 15, 2014
    88
    I neglect the temperature. I think it is not required since beta is given for that temperature
  4. WBahn
    Mar 31, 2012
    18,064
    4,904
    So think about your question. You are given two extraneous pieces of information and you have no problem ignoring one but seem to have a problem ignoring the other.
    Just an observation. May well be reasonable that you are comfortable ignoring one and not the other.
  5. athulascc
    Aug 15, 2014
    88
    so what is that?
    Is ? please tell me how Is come into the picture?
    any equation?
  6. WBahn
    Mar 31, 2012
    18,064
    4,904
    I said that it was extraneous information.
    I just think that it's interesting that you are so concerned about why they gave you Is when you aren't concerned at all about why they gave you the temperature?
    I'd be more puzzled by why they gave Is and Rl to six sig figs while only giving other parameters to one or two sig figs.
  7. Jony130
    Feb 17, 2009
    3,990
    1,115
    But we can use this equation
    I_C = I_S (e^{\frac{Vbe}{Vt}} -1)
    Where Is = 214.447fA
    And we can solve this nonlinear equation using numerical method. For example for Vt = 26mV my computer shows this solution:
    Ic = 3.02283mA and Vbe = 0.607595V
  8. WBahn
    Mar 31, 2012
    18,064
    4,904
    But that is just exchanging one, "Why did they include that?" question for others. Why did they include Vbe=600mV?
  9. MrAl
    Distinguished Member
    Jun 17, 2014
    2,542
    511
    I agree that this is a little unusual because they seem to give some spice data, yet they spec the Vbe voltage at the same time, and the gain given would be a typical actual Beta not BF in the spice model sense, which would probably be higher.
    "Is" is often called the "saturation current", and it fits into the spice model equation for Vbe for example along with another constant "N" (variations on this). But since they already give the Vbe then there doesnt seem to be any good reason why they give this information. The temperature spec could be just to show that there is nothing too diverse about this problem that we might see at elevated or very low temperatures, but why they gave "Is" is a mystery.
    In cases like this the only way to know for sure is to judge this based on the context of the course itself, or ask the instructor. In most courses there is usually a set of agreed upon assumptions and techniques, and that would tell us exactly how to proceed. If that doesnt dictate what to do then they only recourse is to ask the instructor. If there is no instructor then you might try to find the origin of the problem, what document it came from, and that document may give clues as to how they are doing things in general.
    A real quick calculation does show the Vbe to be close to 600mv as per the data sheet, but they give the idealized model there.
  10. athulascc
    Aug 15, 2014
    88
    ok
    thanks lot all and I gained lot of knowleagde
    I did homework well.
